amp wiring question.
will i be able to run a 4g power wire to a distribution block and then have two 4g wires running to the amps? or do i have to run a 4g and two 8g?
tia.
-mikey
tia.
-mikey
I would use the 4 to the block, it will handle the current better.
Then use the higher ones to your equipment.
Last edited by poppakristof; Jan 22, 2008 at 05:22 PM. Reason: edited for reasoning
ok, now a fuse question.
40a and 50a for the amp fuses.
if i have the main power fused, will i need a distribution block with fuses?
if so, do i get a 40a and 50a fuse or can i get higher ampere fuse? can the fuses be different amperes or do they have to be the same? two 120a?
i would think if the main power line is fused, i wouldnt need more fuses at the distribution block, so why do companies offer this option?
If you know the fuse recommended for each amp, add them together to give you what you need to run at the main.
i.e. 20a +30a = 50a at the main.
For double protection, add fuses right before each amp rated for it if you want.
