Amperage Question
Old Oct 17, 2009 | 10:23 AM
yra's Avatar
yra
Default Amperage Question
Pop quiz, for 2-55 watt fogs, what amperage fuses are to be used at the battery and at the fuse box?
thanks
Old Oct 17, 2009 | 01:00 PM
Yoda's Avatar
thanks
20 amps is perfect
Old Oct 17, 2009 | 06:42 PM
Octo's Avatar
Power is voltage times current
current is power divided by voltage
2*55/12=
110/12=
9.16
so a 10 amp fuse would be border line, go with 15 amps or 20 amps
Old Oct 17, 2009 | 07:17 PM
renegadelt1's Avatar
X2 on the 20 amp that's what comes standard with most kits using 2X 55 watt lamps
Old Oct 17, 2009 | 08:16 PM
Yoda's Avatar
2*55/12=
110/12=
9.16
2*55=110
110/12= 9.16
9.16*1.25 (security factor)= 11.45 amps
Therefore 10 amps is not correct. 15 amps would be okay, but it's a little bit close of 15 (peak voltage)
That's why 20 is perfect.
Old Oct 18, 2009 | 04:00 AM
yra's Avatar
yra
Thanks guys, 20 amps. And what about the fuse at the switch, 5 amps ok?
