anybody do the esp switch mod on here?
Aka shutting off the traction control by a flip of the switch. I'm not paying the dealership 120 bucks to flash it. Basically I'm going to do it as a last ditch effort. My alignment is good tire pressure etc good. I just have bigger tires right now
Traction control comes on when over 40 in a slight turn for no reason. I guess its been talked about by many other jeep owners on other forums. I hate it! |
Originally Posted by tribulation138
(Post 3552524)
I've done this mod. Just did it a couple weeks ago. There is a write up on here called "esp kill switch write-up"
Originally Posted by madmike232
(Post 3552572)
Wow, I was just googling and youtubing how to do this! I figure why not try ? Let me know how it goes. |
the "wheel dance" is actually pretty simple and its free. I did it and it solved all issues i was having.
Originally Posted by srt8ftw
(Post 3552601)
Steering wheel dance doesn't work on 2012+. Not sure about 2011's. You could just pull the fuse, i think its J4. Only problem is, you also lose cruise and ABS if you care...
The ESP kill switch is much easier to install than it would seem. I use mine A LOT since having installed this minor but effective little switch.:yup:Either of these will help ya out.
https://www.jk-forum.com/forums/jk-w...ort-jk-264528/ https://www.jk-forum.com/forums/jk-w...riteup-260247/ |
Well I just tried doing the dance for 20 mins outside. What a pain. It only works in 4h. I need it to work in 2wd. And it goes back on when I shut the car off. Wtf. I'm gonna do a rocker switch
1 Attachment(s)
Well I finally did it. Took a whole 5 minutes to do. I just have to mount it and drill a hole.
Attachment 457795 |
| All times are GMT -8. The time now is 03:06 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
