Anyone using a Bazooka tube or otherwise powered subwoofer?
#21
Recommend the Basslink I do...
Haven't had any experience with the Basslink II module though....(for those who don't know, it's a card that slides into the Basslink II that is a 4 channel amp that you can power your door speakers off of...so you'd have the Basslink sub, and an amp for your door speakers all in one package)
Factory HU is probably around 10-15 watts rms per channel.....I think.
#23
i got 2 12" in a box that i got in box that can be quickly takin out and put in by 2 wires that on quick connect and i put the amp under the drivers set and i put it on top a a peice of woods so it wouldnt get wet it hits realy hard
#25
I have a 10" 300W powered subwoofer tube made by Fusion. It's cool, because it was only $97.00 at Fry's Electronics with the hookup wiring kit and all you need to install. But I like it best as it fits great right behind the seat and it has a flat bottom which I put velcro strips on to secure to carpet. When I wheel with the back seat out I move it forward and bungee it to the hold downs and it goes no where. I have been very impressed with it's sound and of course I keep it turned way down because it could be crazy loud if I wanted. The price just can't be beat. I picked this so I would not have to worry about someone stealing a sub that was $300 or something. Also, I had a 10" bazooka tube before that did not sound half as good as this does.
#28
i got the mopar kicker acessory sub its a 10 inch sqaure with a 200 watt amp the amp mounts under the steering column in the dash and the sub goes right behind the rear seat and simply unplugs and unhooks from the seat for easy removal i have pics in my project jk gallery
#30
Bazooka
I am looking for just a little more bass from my audio system. I have replaced the headunit and the four speakers and I am now considering one of those Bazooka tubes. Has anyone installed any of these and can share the results?
Also where did you mount it? I have a two door soft top that gets wet alot in the summer.
