ARB Bumper Wiring
Wrapping up my ARB Bumper install. In the instructions they have you wire up the square amber lights as blinkers by using a wiring loom with relays. I have decided that I just want to use the lights as running lights. I plan on getting a bulb with a bit less wattage so I don't having problems melting the lenses. Am I good to go if I just tap power off of the round turn/running lights without relays? Is the center or outer wire the power for the running lights?
Thanks for the help.
