Auto door Lock problem
Old Jan 26, 2009 | 05:48 PM
joshjr23r6's Avatar
Default Auto door Lock problem
The auto door locks on my Jeep are not working when you go over 15 mph does anyone know how that happened and how to fix my problem?
Old Jan 26, 2009 | 06:03 PM
Adam3612's Avatar
This happend to me right after I got my jeep, take it to the dealer, they need to use that obdII scan thingahmajig (I think thats what its called) to fix it.
Old Jan 26, 2009 | 08:11 PM
downunderdave's Avatar
No need to go to the dealer.
The “Automatic Door Locks” feature can be enabled or disabled as follows:
1. Close all doors and place the key in the ignition.
2. Cycle the ignition switch between LOCK and ON and then back to LOCK four times ending up in the LOCK position.
3. Depress the power door LOCK switch to lock the doors.
4. A single chime will indicate the completion of the programming.
5. Repeat these steps if you want to return this feature to its previous setting.
That'll cure things.. all the best Dave.
Old Jan 27, 2009 | 12:38 AM
clubber's Avatar
If you want to disable, step three is the same?
Old Jan 27, 2009 | 02:55 AM
Yes use the same steps. I've put mine on and off.
Old Jan 27, 2009 | 05:16 AM
joshjr23r6's Avatar
Thank you for the info.
Old Jan 27, 2009 | 05:31 AM
Adam3612's Avatar
Any idea how to enable the sound horn on lock feature? I've tried what the manual says numerous times and it just doesn't seem to work.
Old Jan 27, 2009 | 03:35 PM
joshjr23r6's Avatar
That did not work do you do the key fast or slow
Old Jan 27, 2009 | 06:02 PM
smuhhh's Avatar
I don't think you know how lucky you are that your horn doesn't honk when you lock the doors. I hate life becuase of it and I can't turn it off.
Old Jan 28, 2009 | 02:31 AM
clubber's Avatar
I shut my horn off.....got the instructions on here somewhere.....look in write-ups....worked the first time.
