aux. question
Do you have headphones for your phone? if you do and they work stereo then look at the plugs side by side and see if they are spaced the same. You could try pulling the plug out just a hair and see if the other channel comes on.
Mine iPhone use to play in stereo through aux but now it's mono. I believe something is screwy with the head unit after trying different combinations and concluding it's not the cable or the phone.
try plugging in something else to the system (using the same cable) that you think plays stereo output... if it still doesn't work then you have a problem with the cables you purchased just like mentioned on the other posts... it could also be a problem with the radio but I doubt it... which system do you have? is it the stock radio? if so, is it RES, REQ?
Try pushing the connector in just a little bit further? that extra 1/16th of an inch can mean the difference betwix mono and stereo
