back up camera?
Old Dec 28, 2008 | 10:48 PM
cazo's Avatar
Default back up camera?
I just picked up a back up camera from the junk yard off a 2008 Dodge minivan and was wondering how to hook it up to my gig radio. The minivan had my gig but i did not get the wiring for it. Any help would be nice. Thank you
Old Dec 29, 2008 | 05:35 AM
tgrt's Avatar
Former Vendor
I cannot help you too much, but from what I understand you'll need something called the lockpick to unlock the functionality in the neutered MyGig.
Old Dec 29, 2008 | 05:54 AM
hscrugby's Avatar
Since it's an OE camera, from an 08 minivan, I THINK they were high speed canbus.
I believe the OE camera's interface with the can bus, as well as run up to the back of the radio. (I could be wrong, but I can try and find out)
I'll also be able to get you the pins you'll need to connect the camera to on the back of the mygig. If you've looked at your radio, there are three "plugs" back there. One is primarily speaker/amp output. One is for the mic, and the third is VES and camera.
You'll have to do something creative to get the wire to those plugs, but that can be done from Radio Shack fairly easily.
Old Dec 29, 2008 | 08:26 AM
hscrugby's Avatar
OK, I was wrong. Camera does NOT plug into the canbus, just into the mygig.
Here is the pinout from that "other" plug on the back of the mygig. Pins 3, 4, and 5 are the important ones for you.
CAV CIRCUIT FUNCTION
1
X552 20GY/LB
VDO-AUDIO RETURN 3
2
3
X970 22GY/OR
CAMERA SIGNAL
4
X971 22GY/LB
CAMERA RETURN
5
X972 22
CAMERA SHIELD
6
X534 22GY/OR
VDO-VIDEO SIGNAL 1
7
X535 22GY/LB
VDO-VIDEO COMMON 1
8
X536 22
VDO-VIDEO SHIELD 1
9
X541 22GY/OR
VDO-VIDEO SIGNAL 2
10
X542 22GY/LB
VDO-VIDEO COMMON 2
11
X543 22
VDO-VIDEO SHIELD 2
12
X546 20GY/OR
VDO-AUDIO RETURN 2
13
X551 22DG/VT
VDO-AUDIO LEFT 3
14
X550 22DG/YL
VDO-AUDIO RIGHT 3
15
16
17
18
X539 22DG/TN
VDO-AUDIO LEFT 1
19
X540 22GY/VT
VDO-AUDIO RETURN 1
20
X538 22DG/WT
VDO-AUDIO RIGHT 1
21
X545 20DG/LB
VDO-AUDIO LEFT 2
22
X544 20DG/DB
VDO-AUDIO RIGHT 2
Old Dec 29, 2008 | 02:24 PM
cazo's Avatar
Default ty
Thanks for your help hscrugby, i will go to radio shack to see if they carry the connector.
Old Dec 29, 2008 | 02:28 PM
hscrugby's Avatar
You'll have to make something with some creativity. And just attach them to the pins one at a time. (That will be easiest, or get that plug from the junkyard, and then splice into the wires.)
Good luck.
Old Dec 29, 2008 | 06:26 PM
CIJeep's Avatar
Or you can buy a complete wireless camera setup for 99.00 from target.
Old Dec 29, 2008 | 07:10 PM
renegadelt1's Avatar
The connector is available from metraonline.com. I had the dealer add the backup camera option with the starscan tool, That was much less $$$ then a lockpick.
Old Dec 30, 2008 | 06:13 AM
jwilson2598's Avatar
Renegade, do you have a part number or link for that connector? I was think about using the same one to hook up a screen for my 6 disc, since the connector is the same.
Also, to the OP, take not of renegade's comment...just plugging in the camera alone will not turn it on, you'll need to have it activated by StarScan
Old Dec 31, 2008 | 06:53 PM
Originally Posted by Moose512
The only thing I can contribute to this thread (I have an aftermarket head unit) is to mount the camera high enough in the back so that it does not submerge during water crossings.
Most cameras (regardless of price) are not waterproof. I am on my 4th camera and as soon as my new carrier arrives I will relocate the camera to the middle of my spare. Hope this helps.
You are correct water “Proof” cameras are very hard to come by I am using a Crime Stopper Model number SV-6700 Waterproof I made a bracket That mounts between the top spokes on the spare wheel, The camera is color reverse view also has somewhat of a fish eye view. Works very well.
