Backup Camera Mounting
So, it seems everyone is running either the 1/4" round backup camera mounted in the rear bumper or the little 1" square guy on the spare tire rack.
I'm curious if anyone's install anything a little beefier than those two. I've been looking at a couple on AliExpress that have parking sensors built in with them. One even has a built in distance meter. I'd love to use that one but I'm not even sure if I'd have anywhere I could mount it. I'm curious where you're all getting your mounting brackets or if you're fabbing them up yourselves. |
1 Attachment(s)
I mounted mine in the tire center hub with quick disconnects behind. It has the parking assist lines
Attachment 627105 |
Originally Posted by Skippman
(Post 4151120)
I bought a piece of aluminum from home Depot cut it, bent it and screwed the camera to it. Painted it matte black and it's perfectly poking out my rim. I will post pictures tomorrow.
1 Attachment(s)
Here is mine, the center cap is an amazing idea, wish I had of thought of that
Originally Posted by andrew putnam
(Post 4151134)
Attachment 627105 |
Curious to see where everyone is exiting the body to run your b/u camera wires externally. Currently I have the wires tucked and running inside down the passenger side. My original thought was to place it in the rear bumper for a clean out of the way install.....
Thanks for any input / suggestions. |
2 Attachment(s)
My camera is mounted on the tire carrier and the wires are ran into the third light grommet, through the door, into the gate loom, up the passenger side of the jeep, into the dash plugged into the headunit. See attached.
Attachment 672207Attachment 672208 |
5 Attachment(s)
mounted mine here...spare comes off without having to mess with camera, wires or anything. I wanted mine a little higher and have I it wired to a toggle switch inside as well as the reverse circuit. I did this so i can flip it on manually and check the load on the trailer as i'm driving. It works great for me. used electrical elbow and painted it black...camera i used fit perfectly inside. Pretty crappy pics i know.
Attachment 673316Attachment 673317Attachment 673318Attachment 673319Attachment 673320 |
1 Attachment(s)
