Battery Light Problem
Old Nov 3, 2009 | 08:13 AM
Default Battery Light Problem
Hey everyone I was hoping to get some help with a problem here it is:
I installed the dual battery kit with the smart isolator. Now when I turn the jeep on the battery light comes on and stays on the entire time the jeep is running. I checked both batteries and they are holding a charge. The only time I can get the light to go out is after I have been driving for with the light on, I stop for a short time and then start the jeep again. Then the light never comes on. I checked the wiring and I can't see anything wrong.
Any help would be appreciated,
Dan
Last edited by Dmerk524; Nov 3, 2009 at 12:40 PM. Reason: used a bad word to refer to a jeep
Old Nov 3, 2009 | 09:34 AM
DavidAYJJK's Avatar
Which dual battery kit?
Old Nov 3, 2009 | 10:02 AM
Default benchmark
benchmark smarty kit
Old Nov 3, 2009 | 11:32 AM
Benchmark Designs Inc.'s Avatar
Hey Dan,
Just got your voicemail (I'm in LV at SEMA).
What's the battery voltage on with the Jeep running?
John
Old Nov 3, 2009 | 11:57 AM
RedneckJeep's Avatar
Three poor little kittens.
Old Nov 3, 2009 | 12:39 PM
I have one of those cheap meters that has lights at 5v 12v 12.5v 13v 13.5v and 14v. When the Jeep is running both batteries are register the highest 14.0v
Old Nov 3, 2009 | 12:47 PM
whpony96's Avatar
Chances are it's the jeep reading it as a OVER VOLTAGE..not a low voltage condition..
Old Nov 3, 2009 | 12:54 PM
Default Idk
I thought about that but then why does the light not come on when the jeep is restarted after running for awhile. I would think that would be when both batteries are fully charged and combined?
Old Dec 30, 2009 | 04:34 PM
petrus's Avatar
So what was the resolution here? I may have a similar situation. I have an auxiliary battery with a no-name battery isolator from Pep Boys. It ran fine for a year, but over the past several months I've noticed the voltage creeping up. It now sits at 15.1 to 15.4 volts going down the expressway, and every once in a while I'll get an overvoltage fault, when it fluctuates over 16 volts. The auxiliary battery checked out fine. Any ideas before I'm forced to make a trip to the dealer?
