Battery Wire Management
Anyone have a good idea on how to clean up the wires connected to the battery? My CB, light bar, and winch are beginning to create a large amount of loose wires around the battery and is affecting my OCD! I've thought about using a wire terminal block, but I don't know of anyone who has used one. Thoughts?
sPOD. It's a fuse and relay block extension for your battery. Really cleans up the wiring, as well as the controls inside the cab. The sPOD is a very neat install (addressing that OCD, you can even have custom-made switch toggles and modify the sPOD for backlighting wired to the dash light control). I also added an oil pressure gauge with mine (the gauge hole is optional) ...
There are various configurations and ways to provide for winch control through it. Do your research. There are also competing products that I'm sure others will chime in about.
Here's what I did; only took an afternoon to fabricate and wire.
The Blue Sea block can be purchased at West Marine or several locations on-line
https://www.jk-forum.com/forums/jk-s...-panel-266459/
That's exactly what I was looking at doing. Thanks.
Looks clean.
