Black magic install help!
Just got my new black magic lights and I opened it up and got really confused! I don't have a lot of time to monkey around with it so I was wondering if anyone had a write up (preferably with pictures) I tried searching but the search on my phone doesn't work to great. I'd like to wire it so I can turn them on without having my jeep turned on or without having my headlights or fog lights on. Any help is greatly appreciated!
I hope this helps a little, but if you have any more questions I might be able to help. I can probably take some pictures of needed too.
That's great stuff, but the thing is.. I've done electrical on houses, boats, campers.. You name it. But never a vehicle! And frankly it confuses the hell out of me! How do you tap into the passenger side? And do I need to get anything that doesn't come with it?
As far as parts needed, I got some wire connectors, wire, splice connectors and terminal ends to hook to the battery. I also installed a Rugged Ridge A-Pillar switch pack at the same time, so I chewed up a lot of wire making hooking all 4 switches up and making a wire harness. I would also recomend beer. It got frustrationg at times routing the wires and taking crap off so I could get to where I needed. So the thinking beer really comes in handy.
Where are you mounting the lights?
I recommend wiring them so you have to have the key on in order to turn the Black Magics on. Reason is to keep assholes from turning on your lights in a parking and you coming out to a dead battery.
I got kc windshield brackets and for now I'm just gonna be running the one set so I don't need anything too intense. Just pointers on how to run the wires efficiently and where you guys grounded the wires.
There is a small hole that is filled with foam insulation on the drivers side that I ran my switch wire through. Just used a metal coat hanger with the wire taped to it. I put the solenoid near where I ran the wires into the cab. In the engine bay, there is a bunch of wires that you can piggy back from the solenoid to the battery or fuse box. I just hid mine in an existing wire cover.
Sounds fairly straight forward.. I won't be able to get around to it till next Thursday so if you could maybe put up some pictures or a detailed step by step between now and then that would e great!!
