Black wire...no... the blue wire... wait??
sooooooo... i pulled some panels and found the accessory port wires on the driver's side cig lighter port.
Objective: hard wire my XM radio power cord into the back of the driver cig lighter port
Method: good question... that where you all come in!
My XM power cord is the standard dual wire in separate insulation as in, two wires run side by side inside the insulated cord.
The lighter port has a black wire and a blue wire with a redish stripe.
My questions:
1. do i need to cut the adapter off and splice one wire into the black and one into the blue or can they both be spliced into one wire?
2. which wire, black or blue?
3. Are there any other ways you all are accomplishing this??
Thanks in advance and please help, i would like to do this tonight and would prefer to keep the adapter intact in case i need it in another vehicle!
Respectfully,
07JKX
My questions:
Respectfully,
07JKX
and what happens if i the blue wire is ground and the black wire is hot???
BOOOOOM, smoke, fire, armageddon?? or will it just not work?
oh... and do you think i could wire in a radar detector too??
XM Install
Hey guys,
The black wire is ground and the Blue with Red stripe is 12 Volt with the ignition. I hard wired my GPS and checked the Service Manual and verified with a Volt Meter. Hope this helps. Chris
workin on it right now... and damn... they sure didnt leave much slack on the wires... there isnt any easy way to remove the plate that has the lighter ports and the flashers, esp, etc. buttons is there??
