blank swith plate removal
Old Apr 18, 2007 | 12:01 PM
FiveOff's Avatar
here's another option:Cool Tech JK Switch mount
It allows you to mount switches in the wasted space in the center console near the floor.
Not as cool as using the existing switch plate, but at least gives you an option.
Old Apr 18, 2007 | 12:30 PM
The_Superhoo's Avatar
Originally Posted by Gr8gugly
*edit* nevermind what my post here originally said, for some reason the pics suddenly started working when i quoted them lol
Old Apr 29, 2007 | 12:44 PM
captsam54's Avatar
Originally Posted by 07JKX
how do the blank plugs in the switch plate by the hazards come out. i would like to fill some of the blanks with switch for garage door opener, additional lights and anything else? i tried to pop them out, but i didn't[/COLOR] want to break anything.
thanks!
Hey, I was thinking the same thing.. I asked my mods guy at the dealership to order me a couple of switches to go in place of the dummies so i could wire up lights etc.
Haven't heard back yet.. Maybe he can't get them or they don't make/have them..
On another note.. What about trying to get the "Deluxe Version" switch set, that has all the switches, and may be able to wire up the 1st 2 to whatever??
Old Apr 29, 2007 | 01:25 PM
John L's Avatar
Probably won't work as all the switches are most likely momentary contact type with the exception of the hazards. The switches are built into the circuit board, and with the canbus system de-integrating them for use on other electrical items will be impossible. But then I could be totally wrong. Anybody care to jump in here?
Old Apr 29, 2007 | 01:41 PM
zoomzoomjr's Avatar
What is the actual mounting depth than can be used? I can try to find a switch that'll work.
Old Apr 29, 2007 | 01:52 PM
John L's Avatar
It's less than 1/4", if you look at the pics posted above you can see the blank covers removed from the housing, as well as the circuit board that was behind the blanks. I hate what DC did here, makes it tough for modding
Old Apr 29, 2007 | 01:56 PM
Gr8gugly's Avatar
Just from memory I don't think it was more than 1/2". I still would like to know if I need that side of the printed circuit board If I don't have those options? I am in a rented PT Cruiser right now that has the exact same switch console. It however only has Hazards and Pass Airbag info. So it has four blank spots. These part are all the same probably and they only activate what they need. Also momentary switches may be useful if you could get them to work for stuff like garage doors or the like.
Old Apr 29, 2007 | 02:18 PM
John L's Avatar
I guess a total disassemble is in order here, and you're right, the momentary action would be good for openers. The extra switches would still bear the intended logo on them though if another stock panel with the extra switches was used. A simple latch circuit could turn a momentary switch into a on/off type as well. Push once for on, push again for off.
Old Apr 29, 2007 | 04:34 PM
ScooterS's Avatar
Lots of room to the left of the stearing wheel for buttons/switches.
