Blinkers both flashing - Not Hyper
Old Aug 27, 2020 | 11:03 AM
Seanjenk's Avatar
Default Blinkers both flashing - Not Hyper
Need some help here. 2015 JK Sahara unlimited 4 door. My blinkers are not working left or right using the indicator, both blinkers just flash normal speed not hyper. Here is what I have and have done so far
1. LED headlights
2. LED tail lights
3. LED bulbs in the fog lights in front bumper
4. Stock bulbs in front indicators- those yellow ones
5. license plate relocation plate with license plate light and 3rd light -set up is LED - triple checked this install- disconnected this set up and still blinkers wont work right
6. Checked for grounded wires cant seem to locate anything loose or out of place
7. New Indicator switch installed - no change
8. Checked all the fuses - nothing blown
9. Changed the Capacitors in the rear tail lights
Does anyone have a suggestion or solution? I did read taking the LED bulbs out of the fog lights should do the trick but I disconnected the fog lights and the blinkers still dont work
