Broken Rear Defrost on 07' 2 door hard top!
Old Oct 1, 2009 | 08:56 PM
emtjeep's Avatar
Default Broken Rear Defrost on 07' 2 door hard top!
The wire that connects to the rear window just came off. I opened my rear tail gate and raised the window and it broke off. Looks like the solder just split from the glass. Any quick fixes? Need it for the up and coming fall/winter.
Thanks,
J
Old Oct 1, 2009 | 09:13 PM
whpony96's Avatar
Yep you an re-solder it back on! I did on my mustang when the same thing happened to me when I was cleaning the windows..
Old Oct 2, 2009 | 01:11 AM
renegadelt1's Avatar
Before you try applying that much heat to the glass they make a kit here’s a link frostfighter.com it’s like a solder/epoxy that works without heat, I used it on my TJ it was broke when I bought the hard top it was still holding 2 years later when I sold my TJ.
Hope this helps
Old Oct 2, 2009 | 06:54 PM
chasew's Avatar
i had the same thing happen on my 07 2 door went to the dealer and it was fixed no charge
