Can I make a 2010 RER nav work on my 2007 JK?
All Year Wranglers are High speed.....any mygig that worked in another wrangler will work in All Wranglers....only change was from RER to RHR and the RHB use a combo Sat Radio/GPS Antenna..Wrangler got the MyGig Before the Higher Priced Cars did...lol
i just put a 10 RER in my 09 and it works fine. just double check the Part #
on here (Jeep Grand Cherokee WK - MyGIG Multimedia Infotainment System - parts) it will let you know if the
unit it's if HIGH or LOW speed and i just checked and a 07 is HIGH speed so
just double check the unit is to.
Side Note: make sure to take out the cd you have in your old unit before unplugging
and putting in the new unit...
Sinkic
Sinkic
MyGig, All Day & All Night
http://mofv.com/mygig/
Software updates, any info you need on it...
If you have the Mopar p/n....Go To
MoparPartsOverstock.com and top right enter the p/n it will take you the Info of what it is and show all Vehicles it Goes to...If p/n starts with a 5, be sure to put a zero before it, a 4 gets it taken off the p/n and all Letters before a p/n needs to be removed....
