can you splice 2 different guage wires?
I'm wiring KC 5x7 fog lights and I need to add wire from the lights to the relay. The wire running from the 55 watt lights looks like 18 but I have a roll of 16. Will it cause a problem to splice 16 from the relay to the 18 going to the lights?
I asked earlier if anyone knew what guage wire came with the KC wirung harness for these lights, but did not get a reply, so I'm only guessing by comparing the 16 to what came in the harness that it's 18. But if I cn run larger wire from the relay into the smaller wire going to the lights safely, then I will go ahead a splice the two together. Thanks again
