Change state in Mygig nav
Old Jan 5, 2010 | 09:35 PM
rizzosmith's Avatar
Veteran: Marine Corp
Default Change state in Mygig nav
I did the search already. How do I (permanently) change the state (from Michigan to Wash) on the MYGIG navigation ? Any help would be greatly appreciated. Thank you.
Old Jan 6, 2010 | 10:30 AM
horwitzs's Avatar
In the Nav menu there is option to set the default state. I've changed it a few times as I've been moved around the country for work.
I'll look today to find exactly where to find it for you.
Old Jan 6, 2010 | 11:34 AM
rizzosmith's Avatar
Thank you man, I appreciate that
Old Jan 6, 2010 | 02:19 PM
horwitzs's Avatar
When you are in Nav mode, press the Menu button.
There should be a Nav Settings button on the screen. Select it, and there are options to change the default state and country.
Old Jan 7, 2010 | 10:09 PM
rizzosmith's Avatar
Worked like a charm. Thanks for the help.
