Cibie h4 upgrade
Old 11-07-2014, 07:06 PM
ctjeeper's Avatar
Have the Cibies also. Bought the full harness from Dan so I can run the Ozram 100/90w. Both low and high beams are awesome and I never get flashed. Unless I have my stock foglights on, then I do. Go figure...
Old 11-08-2014, 04:05 AM
Jiblet's Avatar
That's a lot of light! How's your bulb life?
I'm almost certain that the stock fogs can be aimed.
Cutoff should be about 1/4 - 1/3 lower than the low beam cutoff from 25 feet.
Old 11-08-2014, 05:06 AM
ctjeeper's Avatar
Hmm. Thanks I'll have to look into that. I didn't think they had an adjustment on them.
Bulb life is OK. I prolly get about a year from a set. When one goes I replace them both and just hang on to the other as a spare. Just had to order a set yesterday...lol
Old 11-08-2014, 07:46 PM
Black2013JK's Avatar
Thanks for the info. Interestingly enough I noticed tonight that my pass side low beam wasn't working. I suppose that is one reason the lights looked so bad. I'm surprised it burned out this quick though, 21k miles in just under a year. I'll take a closer look at my upgrading options. I won't drop the money to go LED so this is a nice alternative.
Old 11-08-2014, 07:52 PM
ctjeeper's Avatar
If you do I highly recommend the full harness vs adapters. You can use higher wattage w harness. Just my two cents...
Old 11-09-2014, 05:10 AM
Jiblet's Avatar
HA! A dead bulb will definitely cut down on the lighting.
FWIW, lenses (and aiming) are the biggest factor. Cibies > Hella/Bosch >> IPF
Someone mentioned Daniel Stern's website. Check it out, lots of info from an expert.
Old 11-13-2014, 02:55 PM
donny27's Avatar
First long drive with the new lights wow high beams are crazy
Old 12-29-2014, 10:35 AM
notnalc68's Avatar
I found these Cibies on Amazon, while reading reviews on Hella. Good reviews and pics. Sold directly by Amazon and appears to be the real thing. http://www.amazon.com/gp/aw/d/B008DQ...le?pc_redir=T1 Great price.
Old 01-03-2015, 11:15 AM
notnalc68's Avatar
Left side is Cibie 7", #082440, with Hella H4 60/55 W. Right side is stock lamp. I used a KC HiLites H13 to H4 conversion jumper, part #6307 & coated all connections with di-electric grease.
Old 01-03-2015, 11:29 AM
bust12's Avatar
Any night shots to show beam patterns?
Quick Reply: Cibie h4 upgrade
