Clock Issues with MyGig Lockpick
I installed the Freedom In Motion Lockpick v5 a few months ago in my 2008 JKU. I noticed my user clock was off by a few minutes, but didn't think too much of it and didn't bother to change it. Now with the daylight savings change, I have come to realize that my Nav/Radio is not allowing me to change the user time. I can get to the clock user screen, make changes to the minutes, hours, etc..., but when I click "Save" no actual change is made to the clock. I even tried setting it to one time zone further back to get it to the right time, but it won't allow that change to be made either. I have removed the fuse thinking this would help reset the clock, but no luck.
All other features seem to be working fine (cameras, nav, radio, HD...). Any ideas? Thx |
Originally Posted by uofawildcats
(Post 3724158)
I installed the Freedom In Motion Lockpick v5 a few months ago in my 2008 JKU. I noticed my user clock was off by a few minutes, but didn't think too much of it and didn't bother to change it. Now with the daylight savings change, I have come to realize that my Nav/Radio is not allowing me to change the user time. I can get to the clock user screen, make changes to the minutes, hours, etc..., but when I click "Save" no actual change is made to the clock. I even tried setting it to one time zone further back to get it to the right time, but it won't allow that change to be made either. I have removed the fuse thinking this would help reset the clock, but no luck. All other features seem to be working fine (cameras, nav, radio, HD...). Any ideas? Thx
Originally Posted by 13Jeep
(Post 3735885)
Check your dip switches, they could be set wrong, I had same problem
Same issue here. I also have the lockpick. I just replaced the gps antenna over the weekend too (the old one may have been damaged when I pulled on its cord in the install) but that did not make a difference. The time cannot be changed - User Time is ignored and the gps time does not update. The only way to set the time is to pull the fuse when the real time is 12:00.
Originally Posted by cydnub
(Post 3752702)
My GPS time doesn't seem to have any correlation to the actual time. It is off by something like 6.5 hours. Not sure why it is not working. I guess at this point I don't care so much about the GPS time since I was able to manually reset the time using the method I described. I just always use the User Clock instead of the GPS time. |
GPS Time
did you set the time zone? that's how it adjusts GPS time.
although, since it knows where you ... are... it should know which time zone your in... lol. |
Originally Posted by SabrToothSqrl
(Post 3752845)
did you set the time zone? that's how it adjusts GPS time. although, since it knows where you ... are... it should know which time zone your in... lol.
(Post 3752897)
Time zone is correct. The GPS time is off on both hour and minutes by about 6.5 hours, so it's not even close. Not sure why.
(Post 3820141)
It's been a few months now and the User Clock is off by about 5 minutes now. Would sure like to just use GPS time, but my GPS time is not even close to being correct. Anybody have any thoughts why my GPS clock would be off by so much? All other features besides the clocks are working fine.
(Post 3823217)
Check your dip switches, I found mine off just slightly, I reset them , works perfect now
