Code P0481 fan 2 control circuit
Old Aug 11, 2019 | 09:52 AM
Steven Emile's Avatar
Default Code P0481 fan 2 control circuit
I'm new here, so thanks for taking the time to read this! Was recommended to join this group buy a friend as I'm having a few electrical issues I have no idea how to fix.
My 2007 Wrangler jku has thrown code p0481 a few times now. The first time I check the code they recommended I replace tipm, second time and third time it only said fan 2 control circuit.
Any insight into this? Dealer here locally seems to have no clue.
Old Aug 11, 2019 | 10:55 AM
rob_engineer's Avatar
On my 2012 I had a fan circuit problem. Turns out it was due to a loose battery terminal. Tightened the terminal and the fault and higher temps went away
Old Aug 11, 2019 | 12:05 PM
LC Boyer's Avatar
Vet Army
Check all the electrical connections
Old Aug 11, 2019 | 04:30 PM
Mr.T's Avatar
Community Favorite
Lightbulb
From the service manual...
P0481 (2008)
Set Condition:
The PCM is requesting the TIPM to turn on the Cooling Fan On and it is not operating. One Trip Fault. Three good trips to turn off the MIL.
Possible Causes
  • CAN C BUS FAILURE
  • ENGINE COOLANT TEMP SENSOR DTCS SET
  • COOLING FAN CONTROL CIRCUIT DTCS SET IN THE TIPM
  • PCM
Hopefully there is actually another DTC that will get you closer. I'd start by activating the fan on high with a scan tool/software and see if it works.
Old Nov 2, 2019 | 05:42 AM
pazitive44's Avatar
Default Loose connection
My Fusible link cable was dirty and loose ...
I had a p0480 code....I reset DTC...going on 80 miles so far
It hasn't come back ....
