Cooling fan and temp gauge mystery
up on top!
Got the same problem again, since cold weathers are back. A friend of mine also has this issue with his 2013.
They replaced the sensor again (different dealer) but problem is still there. I have read on another forum that the use of the engine bloc heater could correlate with this issue due to the fact that the coolant should be colder and the pcm think the sensor is irrational.
Anybody had this issue solved?
up on top!
