Dash lights flashing and wont start!! Help!!
Old Jul 15, 2012 | 07:24 PM
rpc2638's Avatar
Default Dash lights flashing and wont start!! Help!!
I had just put the doors back on my jeep because it's suppose to rain and now The jeep won't start and the dash lights flicker like crazy! You can hear all the relays flashing inside The fuse box under the hood, I checked batt voltage and am getting 12.2 volts with and w/out cables connected to it. With just the key forward the positive terminal on the batterie gets hot and pretty quick. I am thinking the starter solenoid is bad, but what do y'all think? Anyone else have a similar problem??
P.S. yes I did unplug all the door connectors and try again but was also a fail.
Any feed back will greatly be appreciated thanks!
Old Jul 15, 2012 | 08:22 PM
rpc2638's Avatar
Now I'm only getting 6-8 volts when cables are connected even with the key off!! Confused someone help!
Old Jul 15, 2012 | 10:16 PM
jk bobby's Avatar
Did you install an aftermarket alarm?
Old Jul 16, 2012 | 04:18 AM
rpc2638's Avatar
No I haven't. I talked with another tech and he told me my battery might be shorted out. He said if I had jumped off another car it could happen. And I did yesterday morning but didn't drive it again until the afternoon. So I am going to rob the battery out of my p/up and give it a shot today.
I also bench tested my starter and it kicks out and spins with no problem not even any lag.
Old Jul 16, 2012 | 01:38 PM
Sahara Lee's Avatar
Default Corrosion?
Sounds like you have a bad cable comnnection on you battery. To check this, put you meter directly on the battery poles, not the clamps. If the voltage doesn't drop you need to clean your battery connecitions. If the voltage does drop then your battery is bad.
Old Jul 16, 2012 | 08:19 PM
rpc2638's Avatar
It was a bad battery. Put a new one in today. Glad it wasn't anything major!
Old Jul 16, 2012 | 08:34 PM
jk bobby's Avatar
phew~~~ i wish that all problems were solved that easy. I'd check your alternator too, jump starting a car does horrors on your alternator. i learned the hard way and now carry a booster pack. congrats on putting your jeep back on the road where it belongs!
Old Jul 17, 2012 | 04:50 AM
Ryan0260's Avatar
This is exactly what I was going to suggest...
Old Jul 17, 2012 | 09:39 AM
rpc2638's Avatar
Got some rain last night I believe I'm gonna hit the dunes afterwork! Aught to be legit!!
Old Aug 14, 2012 | 11:23 AM
Faulket's Avatar
I'm having trouble with my jeep starting, too. I did some wiring with lights and I have an aftermarket alarm. what could have gone wrong with that?
