Day time Driving
Old Mar 25, 2020 | 09:09 AM
funnnyfarm's Avatar
Default Day time Driving
I have a 2014 JK built in Canada. It has day time driving lights ( apparently all vehicles suppose to have it up there). I should of said I had day time driving lights, they don’t work any more. I have a schematics from mitchell 1. And the schematics from Jeep are worst. Anybody know how it is routed or anything about the subject. Thanks Al Cassell
Old Mar 25, 2020 | 01:46 PM
Mr.T's Avatar
Community Favorite
DRL's are a programmed feature. If the low beam headlamps work, it's not electrical. DRL's just supply a lower voltage to the low beams. They only light up with the e-brake off with the transmission in gear (auto trans only). By any chance, was it in park or the e-brake on when checked?
Old Mar 25, 2020 | 06:45 PM
funnnyfarm's Avatar
I have low beam when I rotate the light switch, and hi beam works. I just lost DRL about a month ago. park brake is fully off. when I put it in gear no DRL. Where dose the lower voltage come from? Thanks Al Cassell
Old Mar 25, 2020 | 08:39 PM
Mr.T's Avatar
Community Favorite
The TIPM, probably PWM (pulse width modulation). Sounds like DRL was turned off. Was there any work done just before it stopped working? There are OBD2 tools that program DRL on and off, most common being the AEV procal.
Old Mar 25, 2020 | 08:55 PM
funnnyfarm's Avatar
Thanks Mr.T. I’ll do more investigation and let you know. Al Cassell
Old Mar 27, 2020 | 06:13 PM
karls10jk's Avatar
Jscan can also do the DRL if he just needs it turned back on.
