Daystar or RR switch panel?
Old Feb 4, 2011 | 02:25 AM
rickster's Avatar
Originally Posted by TonyT
BUT then you've got every idiot pushing your buttons as they walk by your jeep when the windows are down or the doors are off.
Just wire them into the ignition and they will not work without the key.
Old Feb 4, 2011 | 01:19 PM
Tgoods 09 X's Avatar
I have a 6 speed and I went with the daystar panel. But I mounted it like this.
People screwing with them is a big issue for me as well, but I wanted them to have constant power without having to turn on the ignition. So when things warm up I will be installing a power switch somewhere that will turn on an aux fuse block that all of those switches are wired through!
Old Feb 4, 2011 | 02:02 PM
sm_rubi's Avatar
Nice job!
Old Feb 4, 2011 | 02:43 PM
TURTLECON's Avatar
Just get a sticker like this....
Old Feb 4, 2011 | 04:44 PM
coastie kyle's Avatar
Veteran: Coast Guard
How do you wire them through the ignition? All I saw was a big wire bundle. Which one is the ignition?
Old Feb 4, 2011 | 07:48 PM
Orangeav's Avatar
Can't you run power off the cig lighter/12V plug and limit power to when the ignition is on?
Old Feb 5, 2011 | 08:52 AM
I like it, Im trying it.....
Old Feb 5, 2011 | 02:46 PM
Nedward44's Avatar
Default Switches
Get more lights and accessories and do both!
Old Feb 5, 2011 | 03:52 PM
Orangeav's Avatar
Originally Posted by Riptide
You can. Many do. But then you're limiting when the lights can be used as you need to have the jeep on.
Roger that, I didn't think of that aspect!
Old Feb 5, 2011 | 04:01 PM
OverKill's Avatar
Vet Army
Default RR Panel
I just took my panel out, drilled a hole for the light switch. Used a swith from the parts store. It is just a flat rocker switch and is gray. My wife drove the jeep and did not know the switch was there. It is not obvious like the switchs shown on the threads. I don't know about everybody else, but I have a hard time spending good money when I can do it myself. I saw this on somebody else's jeep a while back.
