Dead Battery
Old Jun 16, 2013 | 03:23 PM
Black-Shadow's Avatar
Default Im starting to agree
Originally Posted by Rednroll
This is actually a pretty common cause for battery failures for OEM batteries on the JK. That's also why most of us buy AGM/Gel cell replacement batteries to avoid this.
Im beginning to think it was just a bad battery, alternator after testing is fine also
Old Jun 16, 2013 | 06:36 PM
Ryan0260's Avatar
It probably was. It happens more than you would imagine, even on brand new vehicles. Did this not get replaced under warranty?
Old Jun 16, 2013 | 07:02 PM
txjeeplover's Avatar
My factory battery died after a year. I worked part-time at Autozone when I was an undergraduate, and I learned then that it is very common for factory batteries in new cars to die after one or two years.
Old Jun 18, 2013 | 01:43 AM
Macman1138's Avatar
Theres a couple of threads on weird warning lights flashing and jeeps not starting but nobody talks about a dead battery on a year old Jeep. 2012 wrangler sport unlimited / auto.
This is what happened;
1-went off-roading
2-while driving home the road slip dummy light came on (didnt think anything of it)
3- got home and pressure washed the mud off
4- next morning went to start it and it would not start (interior lights were dim)
5- tried to jump start jeep from another jeep (unsuccessful)
6- checked voltage at battery (read 17amps wtf?)
7- tapped battery with rubber hammer on top, and retook voltage (read 9amps wtf?)
8- found battery terminals were tight at the nut but did not seem to grip the battery stud fully (could move terminal side to side)
9- only accessary on battery terminals was a winch.
10- took jeep in to dealer becuase it was under warranty
11- they changed out the bad battery and its been fine since
MY QUESTION IS, WHAT KILLED THE BATTERY? the power washing? the slightly lose terminal? Off ROADING (battery plates shifted?)
I want to avoid this happening again.
A few months after buying my COD in 2011, the battery showed signs of failing.
My wife wanted me to take it to the dealer for a replacement.
Instead, I went to Sears and bought their best Die Hard.
OEM batteries suck.
Old Jun 18, 2013 | 01:46 AM
Macman1138's Avatar
Originally Posted by Ryan0260
It could have just been a bad battery from the factory..
I was thinking the same thing.
I had a similar problem and I simply replaced the battery.
Old Jun 18, 2013 | 04:49 PM
Default Warranty
Yes they replaced it under warranty
Old Jun 22, 2013 | 11:39 AM
thegoat's Avatar
I have a 2008 and have put a new battery in every year to year and a half. I just replaced my battery with a Diehard Platinum deep cycle battery and a week later click no start, tried a second time and it started.
Any ideas?
Old Jun 22, 2013 | 05:02 PM
Any ideas?
If your doing one every year, id check all your accessaries that you've hooked up. Sounds like something has constant power running to it.
