Dimensions of Rigid 10 inch?
I'm planning on ordering a 10inch Spectre bar from Rigid but can't seem to find the dimensions of the feet (center hole to center hole) for mounting. I called Rigid and they could only give me a approx distance between the mounting holes. I know you can turn the feet in or out, but I want to attach it directly to my LOD tabs. Can anyone with a 10 inch Rigid measure the mounting holes on the bottom of the feet? My LOD tabs are 10.5 inches center to center hole. Thanks in advance.
I have a 10 inch E Series. Not sure if they are the same size but I don't mind getting the tape measure out really quick.
EDIT: Just checked out the website and it seems the E Series is a little different in length. Sorry. Good luck!
