disassemble facotry headlight?
Has anyone tried to take seperate the reflector and lense of the factory headlamp...I have heard of baking them at 100 deg till glue get soft... Any ideas..
Thanks in advance.
Chris
Thanks in advance.
Chris
OP, I am sure this has been done in the past because our headlights aren't any different than what most 7" universal seal beam headlights that others vehicles have. I have seen a few guys take it apart as they installed HID projectors kits. I can't remember the thread title but I am sure a quick search will yield some results. Good luck....
I've done this before on other lights, as previous posters have mentioned they have, and my temp/time formula was about 200-250 degrees for 10 minutes and the lenses easily came off of the housings. any way you look at it I sure hope that you need to heat them above 100 degrees because it's 105 outside right now and I certainly don't want my lenses coming off easily right now!
