Dome light issue
Old Oct 5, 2012 | 03:01 AM
Wes1525's Avatar
Default Dome light issue
This might sound like a dumb question but this issue is driving me insane. My dome light will come on when I open my doors but when I turn on the switch from the steering column it doesn't work. I have the Rubicon if that makes any difference.
Old Oct 5, 2012 | 02:19 PM
tazzdogsocal's Avatar
two Q's may be dumb butt - are you turning the column switch the right direction ,
and dose the switch dim the dash ? if not there's prob. a fuse for that switch
or its not connected. good luck
Old Oct 5, 2012 | 02:25 PM
Wes1525's Avatar
Lol the dimmer does work for the dash lights and yes I am turning it in the right direction. I just can't understand for the life of me as to why the dome light will come on when I open my doors but when I turn the switch it doesn't work. The switch used to work but then just stopped working.
Old Oct 5, 2012 | 03:20 PM
ya sorry had to ask , I checked all the column function fuse's pulled one by one
none caused the trouble your having maybe that part of the switch just failed .
Old Oct 5, 2012 | 03:54 PM
Wes1525's Avatar
That's what I'm beginning to think. I just thought maybe there was something I was missing or possibly a trick to fix it...wishful thinking maybe.
Old Oct 5, 2012 | 04:01 PM
moe jk's Avatar
Check the connection plug in the door harness maybe it got pulled.
Old Oct 5, 2012 | 04:07 PM
Wes1525's Avatar
It's funny you say that because now that I think of it I didn't have this problem until I ran with my doors off this summer...I will have to check that tomorrow when I have some daylight. I'll post after I check to let you know if it worked.
Old Oct 5, 2012 | 04:21 PM
Wes1525's Avatar
That might also explain why my automatic door lock has been on the fritz from time to time.
Old Oct 17, 2012 | 09:59 AM
Wes1525's Avatar
Bump...still an ongoing issue...does anyone have any idea as to what might be causing this???
