Door Lock Question
Old Dec 21, 2014 | 03:16 PM
07 Rescue Green's Avatar
Veteran: Navy
Default Door Lock Question
I read the FAQ about having the auto unlock feature and for some reason I can't get mine to work. It's such a pain in the ass to get out and try to open any other door and they are still locked. I have a Sahara so I assume I should be able to change this. I read through the owners manual and just don't see anything on it. Thanks.
Old Dec 21, 2014 | 04:19 PM
ronjenx's Avatar
See if this works:
Set the locks to auto-lock at 15 mph and auto unlock all when either front door is opened
Get in the Jeep, insert the key. Cycle the key from insertion position to "on" position 5 times, upon completing the 5th cycle make sure the key ends in the "on" position, press the unlock switch down once. The locks will actuate and a tone will sound. Programming is complete.
Old Dec 21, 2014 | 04:27 PM
Veteran: Navy
I'll try it, thanks.
Old Dec 23, 2014 | 01:31 PM
Veteran: Navy
Still doesn't work, I wonder what's going on?
Old Dec 23, 2014 | 01:52 PM
ronjenx's Avatar
Was your door open, or closed, when you tried it?
There's a chance these steps don't work on the '07s.
Old Dec 23, 2014 | 02:23 PM
Veteran: Navy
I tried it both ways, would really suck if it didn't work for the 07's but that's normally the way my luck runs.
Old Dec 29, 2014 | 04:07 AM
101gargoyles's Avatar
Former Member
Just wondering On position referring to first position-accessory on? Or second position-run? Could be the stopper for the reset. Not at all talking about third position-start.
Old Dec 29, 2014 | 11:10 AM
Veteran: Navy
I went from completely off all the way to on, not start but where the warning lights come on for self check. I noticed that now the doors don't auto lock but this was the day after I did the procedure with the door locks down twice.
Old Dec 29, 2014 | 11:22 AM
ronjenx's Avatar
Sounds like your '07 responds to the programming procedures, then.
Now try it again with the button on the door down once.
Old Jan 1, 2015 | 08:41 PM
Veteran: Navy
I haven't tried anything else yet but today something wierd happened. After about 15 minutes of driving the door locks locked, I was doing about 60 at the time. I guess there is a small possibility that I bumped it with my knee but it's doubtful. Kinda strange huh.
