Door Locks for 07 Unlimited X (4 door)...need help
Old Aug 22, 2019 | 05:24 AM
wburnham's Avatar
Default Door Locks for 07 Unlimited X (4 door)...need help
Guys,
Need some help. I have a '07 Unlimited X 4 door. Seems 4 of my 5 door locks won't "unlock"
Only the driver front door locks and unlocks (with the key fob or the switch on the door panel). All other doors (even the rear tailgate door) won't unlock.
They all lock just fine (with the key fob or the lock switch on the door panel) BUT 98% of the time, they won't unlock when using the key fob OR using the unlock button on the door panel.
Once in a blue moon they will all unlock...but that's rare. I tried messing with the Key Fob settings (thinking the fob was set to just unlock the front door & not all)...but that does not seem to work.
Plus the switch inside on the door panel doesn't unlock them either which leads me to believe it's not a key fob. I tried switching out fuses as well.
You basically have to manually unlock the doors (which is a pain). Or just take all the doors off...LOL
I think it's probably the door actuators but it's ironic that 4 of the 5 all went out....not just 1 etc.
Anyone have some thoughts/feedback? Has this happened to others?
