double din head unit?
Old Aug 19, 2010 | 08:23 AM
Uafan's Avatar
Default double din head unit?
Guys, I've been looking for a while. Does anyone make a double din kit for a 2010 Wrangler? I'm assuming not, or it won't fit because I can't find one anywhere. One of the electronic shops were going out of business so i got a in dash nav/dvd/mp3/ipod alpine unit for a GREAT price..
Thanks!!
Old Aug 19, 2010 | 09:33 AM
Vernnz's Avatar
The '10 is the same as the '07 - '09. Metra, Scosche, PAC et al make kits for JKs.
Get used to this phrase for double DIN H/Us..."Dash Modification required."
Old Aug 19, 2010 | 10:34 AM
runit3's Avatar
Scosche CR1291B for the dash kit, looks pretty much identical to any Jeep with the MOPAR GPS unit. You will also need Scosche CR07SR to integrate into the CAN-BUS. Space will be tight with that extra harness but you can tuck it into the passenger/driver side pockets behind the metal dash subframe. Just make sure all wire splice/connects are good and you'll be on your way.
You can find the CR07SR on Ebay for a good deal less than $130, get the dash kit from the same vendor and save on shipping.
Old Aug 19, 2010 | 11:27 AM
Uafan's Avatar
Thanks for the quick response.. I'm a little confused as to why I need the CR07SR though..
Old Nov 1, 2010 | 02:11 PM
Uafan's Avatar
bump.. just got around to buying the dash kit. Any idea as to why i'd need a can-bus integrator if i don't have a mygig, or steering wheel controls on my Jeep? It's the base mopar headunit.
Old Nov 1, 2010 | 02:54 PM
JK-Ford's Avatar
Partly to maintain the delayed off function. That is, if you like that function. Also the can-buss does know that the radio is there. A fault code will be generated if the radio is removed from the buss. But the fault would only be noticed by a reader.
Old Nov 1, 2010 | 07:43 PM
Vernnz's Avatar
Also H/Us used to have a Hot, Ignition switched and Ground. The Ingintion switched turned the H/U On or Off. Ours don't work that way. There is a Hot, a Ground and CANBus data lines. The H/U is "told" to turn On or Off. With out the harness cable the H/U would always be On. The dimmer also comes to the H/U as a CANBus command. The harness breaks that out as a wire the H/U can respond to.
