JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   JK Electrical, Lighting & Sound Systems (https://www.jk-forum.com/forums/jk-electrical-lighting-sound-systems-13/)
-   -   DPDT and SPDT help/Question (https://www.jk-forum.com/forums/jk-electrical-lighting-sound-systems-13/dpdt-spdt-help-question-220795/)
anonymark Feb 29, 2012 10:59 AM
1 Attachment(s)
I wired up a set of KC backup lights using a relay and a DPDT switch. I also wired in the dash light to the switch so that I could have it backlight (A contura DPDT). I may not be getting this right. The backup lights com on in position 1 in reverse, not at all in the off position, and completely on in position 3. But,,,,,only if the dash lights are on......I'm thinking I need to have a SPDT and not a dualpole switch.... I'm also noticing that the lights are very dim when the dimmer switch is low....What the heck did I do? I did wire in diodes and in line fuses betewwn the 12v+ and reverse light tap... I will try to put up a diagram soon.
edit: Diagram below:
Diagram:Attachment 283489
JK-Ford Feb 29, 2012 11:18 AM
Sounds like you may have landed your backlighting circuit in the wrong position. By the way, neither a DPDT nor a DPST switch will work like you want it to. You need a "3 Position" switch. So this may be a problem also.
anonymark Feb 29, 2012 11:24 AM
Hmm Ok.. The switch I'm using is a Contura VJD1D66B-ALC77-18B DPDT ON/OFF/ON switch, which I thought was the correct use in this application. What do you mean by "landed" my backlight circuit in the wrong position? Thanks for the help JK Ford.....
JK-Ford Feb 29, 2012 11:35 AM
Here is how the "3 Position switch" needs to be wired. IDK if Cauntra makes a switch like this?
http://i822.photobucket.com/albums/z...Schemattic.jpg
I was thinking that your back light circuit may be shorting with another one of your 12+ sources. I didn't notice your drawing before. And I'm not sure of the pin-out for that switch. Give me a minute to research. I do know that the best that you can hope for with a DPDT switch is only 2 functions:1) ON. 2) on with reverse lights. There should be no OFF with this arrangement.
JK-Ford Feb 29, 2012 11:47 AM
OK. Got it. Yes you are getting power from the dash circuit for "source power" @ position 3. Lights will only come on when your dash lights are on. NOT RECOMMENDED. Replace this circuit with power from an accessory power source. .
JK-Ford Feb 29, 2012 11:50 AM
I edited my post. I did say "power from battery". I meant to say "power from accessory circuit".
anonymark Feb 29, 2012 11:59 AM
1 Attachment(s)
Position 3 being the 3rd position in the on/off/on , or position 3 on the switch (ie 3rd pinout?) I'm running a fused and dioded wire from a 12v+ source to pin 6 on the switch, If I get what you mean, I should also be running a "non dimming" accessory power lead to pin out 3 on the switch?
Here's the switch wiring diagram:
Attachment 283504
I just want to make sure I'm clear before I go and rewire.
Thanks for your patience JKFord.....
Geeps Feb 29, 2012 12:03 PM
Remove the wires from your dimmer circuit that are connected to terminals 1 and 3. Power for the lights in the switch is provided by the jumper connected from terminal 5 to terminal 2.
anonymark Feb 29, 2012 12:18 PM
Ahhh Ok. Thank you. I had thought I could wire this to be backlight when the headlights were on.... Extra wiring for nothing. Thank you for the help, I am starting to understand more than just the basics now...
JK-Ford Feb 29, 2012 12:54 PM
No. You have everything correct except for pin #6. This pin needs clean power from an accessory source. IE cig lighter / fuse box.
© 2026 MH Sub I, LLC dba Internet Brands
