DPDT and SPDT help/Question
I wired up a set of KC backup lights using a relay and a DPDT switch. I also wired in the dash light to the switch so that I could have it backlight (A contura DPDT). I may not be getting this right. The backup lights com on in position 1 in reverse, not at all in the off position, and completely on in position 3. But,,,,,only if the dash lights are on......I'm thinking I need to have a SPDT and not a dualpole switch.... I'm also noticing that the lights are very dim when the dimmer switch is low....What the heck did I do? I did wire in diodes and in line fuses betewwn the 12v+ and reverse light tap... I will try to put up a diagram soon.
edit: Diagram below:
Diagram:
Diagram:
Diagram:Attachment 283489
Hmm Ok.. The switch I'm using is a Contura VJD1D66B-ALC77-18B DPDT ON/OFF/ON switch, which I thought was the correct use in this application. What do you mean by "landed" my backlight circuit in the wrong position? Thanks for the help JK Ford.....
I was thinking that your back light circuit may be shorting with another one of your 12+ sources. I didn't notice your drawing before. And I'm not sure of the pin-out for that switch. Give me a minute to research. I do know that the best that you can hope for with a DPDT switch is only 2 functions:1) ON. 2) on with reverse lights. There should be no OFF with this arrangement.
OK. Got it. Yes you are getting power from the dash circuit for "source power" @ position 3. Lights will only come on when your dash lights are on. NOT RECOMMENDED. Replace this circuit with power from an accessory power source. .
Here's the switch wiring diagram:
I just want to make sure I'm clear before I go and rewire.
Thanks for your patience JKFord.....
Ahhh Ok. Thank you. I had thought I could wire this to be backlight when the headlights were on.... Extra wiring for nothing. Thank you for the help, I am starting to understand more than just the basics now...
No. You have everything correct except for pin #6. This pin needs clean power from an accessory source. IE cig lighter / fuse box.
