Dual batteries?
Old Feb 25, 2008 | 09:26 PM
toycop's Avatar
Originally Posted by Living Still
If you are looking for greater power supply you can wire them in series meaning you connect the positive on battery 1 to the negative on battery 2. Then you just have the original cables (feeds or whatever they are actually called) connected to the the negative on battery 1 and the positive on battery 2. For some cool ideas on how to do it really clean https://www.expeditionexchange.com/optima/. I must say that Odyssey batteries are better if you can shell ou the $ for them.
Hopefully this will show (it's a battery connected in series).
I wanted to second the recommendation of Odyssey batteries. I'll have to do some measuring and see if two of their mid-size units would fit in the stock location. Both should surpass the OE specs.
Old Feb 26, 2008 | 04:44 AM
jkpirate's Avatar
The diagram is showing two 6volt batteries connected in series. Thats 12 volts, lots of cranking power, not as much storage. This would work but I don't think its needed. If you need two batteries use two 12 volt batteries connected in parallel( positive to positive, negative to negative).
Old Apr 20, 2008 | 09:33 AM
LinkSync's Avatar
Hey sorry about that! Good thing someone corrected me. I had this conversation with a friend of mine just 2 days ago and I think he seriously confused me lol :confused: . You could build a new battery box for under the hood or Blue Torch Fabrication makes really trick battery boxes that you can put pretty much anywhere. Trunk maybe? http://www.bluetorchfab.com/shop/index.php?cPath=135_174
- Living Still
What trunk?
LMAO
Old Apr 21, 2008 | 07:31 AM
jsmoriss's Avatar
Originally Posted by jkdrone
Once my tax return comes in, I'll have the cash to finish my setup. I have a yellow top that will be mounted under the rear (40%) passenger seat (unfortunately, the seat has to come out to mount/remove it :( ) w/ a hellroaring isolator feeding that and switching between the stock unit and it.
The nice thing about it being under the back seat is that it will be closest as possible to the things feeding off it. (The OBA, the 800/1600W inverter, and, eventually, a fridge.)
jkdrone,
I'm looking at the same setup. No doubt you've spoken to Mike from Hellroaring and you know he doesn't advocate loading the second/backup battery. I'm also planning a fridge, but will connect it to the starter battery side of the selenoid/BIC, leaving the backup battery free. The idea is that IF you run down the starter battery, you can use the backup to "boost" the first. If you load both, then there's a chance you can run down both...
js.
Old Apr 21, 2008 | 08:16 AM
jsmoriss's Avatar
Edit: if you swap out your stock battery for a deep-cycle + starting battery, you can then follow Mike's suggestion just fine. I wouldn't run that fridge off your stock battery though. I've avoided doing this, as I don't want to blow another $170 on another Optima.
I've already swapped out the stocker with a deep cycle, and the backup battery will also be a deep cycle. Not to mention the OTHER two deep cycle batteries in the future trailer (for welding purposes). :-)
js.
Old Apr 21, 2008 | 09:15 AM
eDiveBuddy's Avatar
Yeah, the problem with his suggestion, however, is that the stock battery is not a deep-cycle battery.
Who says you have to use the stock battery as the primary battery? Use the deep cycle to power everything and use the stock as a backup.
I'm putting two bluetops in the new Woods trunk. (As soon as I find the time)
And using the stock as a backup with the Hellroaring isoltor.
Old Apr 21, 2008 | 01:19 PM
eDiveBuddy's Avatar
So you're going to run all your primary wire from the rear of the vehicle back to the front? That seems like it could get expensive real fast
I agree with 100% of what you've said. Especialy this part "it could get expensive real fast." I even chose the location for the same reason as you. Close to where my deep cycle draw will be. B
If when it's all done I measure any significant voltage drop. (2/0 is what I've decided) I will change how it is wired. Back to my original idea, same as yours.
Old Apr 21, 2008 | 05:12 PM
adaycj's Avatar
To simplify, for light duty use as an auxiliary battery you can mount a battery anywhere it will fit and is safe. All you really need is reasonable sized charging wires and circuit protection used with an isolator. Essentially you are just carrying around a spare battery that happens to be charged by the alternator.
I did this for years when my Wife and I used to camp out of a pickup camper. We would travel all day and charge the extra battery. At night we would use the isolated deep cycle battery to run the fridge and lights. When we stayed at a location for many days we would just run a 120v charger.
For winch use, or other high draw applications it won't work easily, but emergency workarounds can happen if you are willing to swap batteries.
I've always felt that the two batteries in one connected tray setup was silly unless you are a hardcore winch guy or you truly need the extended capacity that no single battery can provide. You can do so much more, with less hassle using a isolator and and intelligent circuit protection.
Old Apr 22, 2008 | 09:46 AM
dsy's Avatar
dsy
I've been running dual Batteries fpr over a year now with no problems. Running all my aux loads off the rear battery. If I ever need an emergency jump I can break out the jumper cables and take care of myself.
https://www.jk-forum.com/forums/show...roaring&page=3
Old Dec 1, 2008 | 01:02 AM
Brisnut's Avatar
EEK! Assuming you are talking 2x 12v batteries (dual batteries is useless otherwise)a good way to fry evey electronic part in your vehicle pumping 24VDC into 12VDC equipment.
I moved the Sub woofer forward in the boot area and have just mounted a standard battery tray against one side just inside the tailgate. And that's a sfar as my plan has got so far, the firdge compressor, water pump etc will all run off this battery, and a solenoid will link it to the main when the ignition is on, the trick to this primitive sytem is to always use the same type/size/age batteries
