E-locker indicator
E-locker indicator
Just hooked up my switches and indicator lights for the new OEM Rubicon D44 axles. The rear indicator and light works perfect. The front doesn't... the locker engages, I can hear it clicking, but the indicator light doesn't want to play.
I've checked voltage all the way from the LED-light itself (and it's tested separately as well, and working) to the cable at the diff, no power... probably the indicator is bad, but the axles are brand new and lockers never used.
Any suggestions?
Any suggestions?
I'll have to reply myself. Got help from a friend at another forum and as it shows, the Jeep had to roll a bit, before the indicator indicates that the locker is engaged! So, now both of them work like they should!
