E-Locker use with bad ABS module
Old Nov 20, 2021 | 11:11 AM
woodyvw9's Avatar
Veteran: Coast Guard
Default E-Locker use with bad ABS module
I have a 2008 UNL Rubi with 167K miles and the ABS module has failed. The part is not available until MAR22 (tried several places and all tell the same story). My lockers and sway bars won't operate because none of the speed data gets to the ABS module so ECM can't tell how fast its going (speedo and odometer don't work). Does anyone know a way to use the lockers without wiring switches into the system? Thanks for the help.
