Easy with lots of booobs
Old Jun 10, 2017 | 10:32 PM
jjl509@yahoo.com's Avatar
Exclamation Easy with lots of booobs
Ok so now that I got your attention lol
I have a quick and fast question
I'm installing a fosgate PBR300 x4 ..I am at the point where I tapped into the speaker wires at the back of the harness for the high level converter that in the PBR...but for the outgoing speaker connections I'm kinda lost..so where do I connect to the speakers? Or do I splice tap into the speaker again? Sorry for the easy I should already know this question
Old Jun 11, 2017 | 12:37 PM
Mylil6cyl73's Avatar
Crutchfield had a hire harness that will plug into your factory harness. No cutting.
Old Jun 11, 2017 | 06:32 PM
I think I've read about that harness. I also read that there was no need for it because the amp had a Hilo convert already in it
I attached a pic of where I'm at in the install. As you can see I already tapped into the stock harness right behind the HU (head unit). And ran that too the amp but now do I run outputs and tap back into the stock harness again? I don't think that's right..? Seems so simple but I'm stumped
I can't seem to get the photo to upload from my iPhone to this forum. ugh what a day :((
Old Jun 12, 2017 | 03:06 AM
If you tapped into the factory harness for your supply to the amp then you would just need to go from amp to speakers.
