Electrical help!!! Anyone ever ran into this?
Recently I was pulled over because my tail light was out. I found this hard to believe because it was so new. Anyway long story short, my driver side park lights are out. (Front signal; rear tail) Do not come on when my lights are on. Once I throw my left turn signal both lights work, and when I apply my brake the rear works as well. I have troubleshot the exposed wires that I can see and there are no loose wires. I am wondering if anyone has ran into this before or knows what may be the cause,
process of elimination my friend. pull out the front driver bulb and see if the rear works as it should. if not, replace the front bulb and remove the rear and try again. again if not, remove both front and rear and check if your still having the voltage drop out like you mentioned. more than likely you used an incorrect bulb type somewhere. this once happened to me on another vehicle. good luck
I installed a trailer wiring kit a few months back. I simply took the light out and plugged it in. I did not ground that wiring harness. The ground wire I just left loose. I'm thinking this is it because you install the trailer wiring on the left side.
