Electrical Hookup for Rear Lights
Old Feb 2, 2013 | 04:17 PM
chripczuk's Avatar
Default Electrical Hookup for Rear Lights
3 way rocker to control manual on when pressed up, on with reverse lights only when in center position, and off at all times when down. Took a couple of head scratchers, but here's a basic schematic.
Name:	LOD wiring..jpg
Old Feb 3, 2013 | 03:50 AM
JK-Ford's Avatar
You don't need 2 relays if you use a 3-position switch.
For the reverse lights. I actually prefer to use 2 relays. But I use them a little different. And with a single-pole switch.
