Electronic Throttle Control Light/Limp Mode issue.
Old Sep 23, 2014 | 04:00 PM
jeepsrokay's Avatar
Default Electronic Throttle Control Light/Limp Mode issue.
I purchased my Jeep used around two years ago from a private seller, it is quickly turning into one of the largest mistakes I have ever made. I need any help/info I can get from anyone.
It is a
2009 Jeep Wrangler Sahara
47,000 miles
Automatic Transmission
When I purchased the vehicle, the previous owners failed to mention the issue of the ETC light coming on randomly and putting the car into limp mode, they told me when I purchased it, the problem had been fixed it was a problem with the APP sensor. The dealer replaced the pedal, the wiring harness, the whole thing. I drove it for 6 months without a problem, the first year the light came on maybe twice, it was not a big deal just had to cycle the engine and the light was gone. This summer it comes on 4-5 times a day, I cannot complete most drives without it turning on, the only way to get it to shut off is to cycle the engine. I have now taken it to 3 mechanics, including the dealer and none of which can find a problem.
I have had the throttle body replaced, all of the wires relating to the pedal/throttle body had their voltages checked, the computers have been flashed and reset countless times.
I will give you all the information I have about the error:
The car is spitting out the code P2122, and randomly sometimes P2138 will show up.
The engine does not need to be running for the ETC light to come on, if the key is in the on position without the engine running it will randomly turn on, and stay on until the battery is completely shut off.
It seems to happen much more frequently when the temperature is hot outside 65+.
It only comes on when the engine is up to temperature.
The check engine light does not come on, only the ETC.
The issue has gotten progressively worse the longer I own the car.
Any thoughts, suggestions, possible fixes. Please let me know, being my daily driver this issue is rage inducing. I need to get this issue resolved, I am planning to sell the vehicle. In its current state though that would not only be unethical, I am pretty sure illegal. So please if you have any idea what could be causing this problem, please let me know.
If you need anymore info, just ask.
Old Jan 8, 2015 | 10:29 AM
ashdon3kids's Avatar
BUMP. Anyone have ideas? @jeepsrokay, did you ever resolve your issue? I have a lighting bolt light appear on the dash with codes P0221 and P2135. I am leaning towards throttle position sensor problems based on the codes.
Old Jan 8, 2015 | 04:04 PM
2climbbig's Avatar
Boy that really sucks. Sorry to hear that. With the engine off, are you touching your pedal?
Old Mar 26, 2015 | 08:41 AM
BUMP. Anyone have ideas? I have replaced the throttle body assembly, MOPAR PN 4861661AA and also the pedal, MOPAR PN 53032868AA. I still have the same codes, P0221 and P2135. I'm looking for ideas or maybe a procedure that is needed after these are installed. I clear the codes and they come back after driving.
Old Sep 4, 2016 | 12:42 PM
Owl's Avatar
Owl
It is a
47,000 miles
Did you ever find the gremlin on this? I had the P2138 code spit out at me, for some unknown reason. It cleared itself, and hasn't come back (yet). I'm afraid this might be something that will come back to haunt me.
Both of these codes deal with the Accelerator Pedal Position Sensor. Looking online, I see that the sensor itself is the accelerator pedal assembly. Lots of folks manufacture the item, and the cost appears to be about $75. I've crawled into the area and ensured that the electrical connectors to the pedal assembly are pushed in (even went so far as to remove the connectors / clean / re-seat).
Just wondering if you found out anything on this.
Old Sep 4, 2016 | 01:04 PM
14Sport's Avatar
From ALLDATA but you can't really test it without an active code.
Name:	2014 DTC P2138 Causes.png
Old Sep 10, 2016 | 07:07 AM
Owl's Avatar
Owl
Thanks 14Sport. I'll print this out, with hopes that I wont need it.
Old Sep 10, 2016 | 08:08 AM
14Sport's Avatar
Here's the pinouts too in case you do.
Name:	2014 DTC P2138 Causes Pinout.png
Old Sep 28, 2016 | 09:03 AM
Owl's Avatar
Owl
Thanks 14Sport. Good information. Don't know if the pinouts will be the same for my 2010 or not, but it's a point of reference nonetheless.
Old Apr 10, 2017 | 06:07 AM
Saharacon's Avatar
Did you guys ever figure this one out?
