Eletronics not working
Old Dec 19, 2008 | 04:04 AM
dlincoln91's Avatar
Default Eletronics not working
So this morning after wheeling yesterday i get in my jeep and crank it up
nothin came on excet the radio and the windshieldwippers
after like 30 secounds of running the dash and everything else came on
what happened and is it bad?
Old Dec 19, 2008 | 05:41 AM
jonsjeep's Avatar
yeah, sounds bad. you need to get it checked out..
Old Dec 19, 2008 | 06:10 AM
adgraybda's Avatar
i dunno if this is necisarilly bad (despite it is obviously not good). Happened to me also and fixed itself. Hasnt happened since. Also made a thread about this and got responses from a few other members saying the same thing. I would say check it out if it happens again
Old Dec 19, 2008 | 06:32 AM
wayland1985's Avatar
I'm one of the others who had it happen... Mine lasted more like 15 minutes before it came back on.
Again, hasn't happened a second time...
Old Dec 19, 2008 | 06:42 AM
ronjenx's Avatar
Next time it happens, shut everything off and remove the key. Disconnect the NEGATIVE battery cable for a few minutes. Reconnect it. I'll bet everything will be back to normal. It may fix itself anyway, but this could speed it up a little, and you will feel like you actually did something constructive.
As always, when working on the battery, wear eye protection.
Old Dec 19, 2008 | 11:38 AM
dlincoln91's Avatar
my friend said possibility of just havin a spit of water in the fuse box so i opened it and it was dry as the desert so i dont know maybe just a thing and it has not happened agian
but adgraybda what did you do to help this
Old Dec 19, 2008 | 08:48 PM
Mine pretty much reset itself. I did nothing to help it at all.
I was pretty much getting in to go to work, turned the engine on, and noticed my radio wasn't working. Then I noticed my dash wasn't working... and also noticed my headlights were on, even though the switch was off. My blinkers didn't work either...
I drove the 20 minutes to work in this way, and when i got there, I broke out the manual. While reading, there was a big "CLICK" behind the dash, and suddenly everything came alive...
Old Dec 19, 2008 | 10:02 PM
JackMac4's Avatar
That's what I would do - reboot your jeep.
Old Dec 20, 2008 | 03:40 AM
RubiConz's Avatar
There is a gnome that runs everything under the dash....he falls asleep time to time. I wish we could hook up our PC's/laptop's up to the OBII port and have control of everything.
Old Dec 27, 2008 | 04:16 AM
trick50's Avatar
how cold was it when u were wheeling? did you give her a bath afterwards? I'm thinking something got wet and cold, =frozen. Similar to leaving a laptop in the car overnight when it's 30 degrees or colder out..bring it inside plug it in see what happens.........more then likely nothing until it defrosts 15-20 minutes later...problem is when it defrosts and starts wet things short out...like just happened to my laptop. but this is a car...not a computer it is supposed to be outside so things shouldn't short out...but then again they shouldn't need time to warm up before they work again. hmmm..
