Originally Posted by amt97
(Post 4170964)
I found old copies of various firmware updates for this radio if anyone needs them. PM me.
thank |
I have the 730n RHR, it’s bricked. After screen calibration and master reset. It doesn’t even turn on or open. Does anyone know what to do now? Can I install software to re-flash it? If so, can anyone send me the firmware to my email - robsky87@icloud.com thanks |
Sorry for not paying attention to this thread for quite some time. I've got a copy of the old firmware here since the other site is long gone:
Download this ISO, burn it and you should be good to go: https://drive.google.com/open?id=116...lo7oJ3dtmgVzFg |
(Post 4332630)
Download this ISO, burn it and you should be good to go: https://drive.google.com/open?id=116...lo7oJ3dtmgVzFg Your steps in the original thread is very helpful and gave me hope. I hope you can give assistance on this minor set back. Thanks in advance!! |
RHR 730n screen calibration
Has anyone found out any way at all to get in to a locked calibration screen on the RHR 730n? All the firmware versions I've found for the RHR starts with 2.### so I don't think the 9.### downgrades will work on it. I can get to the engineering menu using the hard keys on the side but since the screen doesn't work, can't page down and select "screen calibration" via the soft keys.
Is there maybe a way to jack some kind of external controller in to the resistive touch screen port where the circuit ribbon connects? I can't find anything to fix this issue for RHR anywhere on the internet. Stuck. Radio works but touchscreen is tweaked. |
Originally Posted by Dannwk
(Post 3655337)
How do you update the software without being able to press "yes" on the screen? I am as stuck as a my gig touch screen after messing around with the calibration. Help!!!
Originally Posted by RRM0221
(Post 4338648)
Thanks very much. Was able to get the ISO image from this thread and was able to burn a copy on a CD. However, I am stuck as I could not press "YES" to confirm the update since the touchscreen is unresponsive. How were you able to do it on yours?
(Post 4332630)
(Post 4332630)
Download this ISO, burn it and you should be good to go: https://drive.google.com/open?id=116...lo7oJ3dtmgVzFg any options to choose yes if the screen's not working? |
Tengo el mismo problema hace ya 7 años-...Mygig REZ....version 9292....aun no puedo presionar SI.....
Alguien lo ha resuelto.??? |
