Esp bas light ???
HAve this light on Also traction control light is on was wheeling all day in 4low and then I stated to leave and my traction control was flashing and trying to brake at the same time so I turned around and washed out my wheels and brakes and was fine the started again then the esp bas light came have no idea what it is and or how to get it off any ideas
Could be the clock spring sensors in the steering wheel....Is the steering wheel centered? Also, check to see if you knocked a speed sensor wire loose. One of my rear wheel speed sensor wires came loose and was not making contact. I just climbed under the Jeep and found the culprit and pushed the wire back in to place. Next time I started the Jeep the dash lights were gone and everybody was happy.
X2. On the bright side, wheel speed sensors made after 09 are about 6 inches longer which is great for added flex and only $22-24 straight from the dealership
I had the same thing happen over the winter while driving through deep snow drifts. If everything is still driving ok. Give it a few days before you dump cash into it. Mine reset itself after about 24 hours and I haven't had a problem since.
Replaced the sensor front driver there was wires exposed and worn down. Cruise control now works but the lights are still on reset battery and my flashcal cleared codes but it doesn't pick up ABS stuff. What now wait?
Brought it to the dealer and they determined it was the hub assembly. Replaced it last week and no lights or codes so far Sent from my iPhone using JK-Forum
