Factory headlight harness short
Thought it was my anti flicker or JW Speaker headlight but after swapping to other side I narrowed it to the green connector / OE harness. Not sure if it's the metal connectors or a short in the wire. I tried taping and zip tie but it goes on/off when I hit bumps - same symptom when I jiggle it. Sometimes only the high beam works. I thought about bending the anti flicker connectors for a tighter fit but I don't want to damage.
Anyone else experience this? Where do I find an OE harness kit?
Thought it was my anti flicker or JW Speaker headlight but after swapping to other side I narrowed it to the green connector / OE harness. Not sure if it's the metal connectors or a short in the wire. I tried taping and zip tie but it goes on/off when I hit bumps - same symptom when I jiggle it. Sometimes only the high beam works. I thought about bending the anti flicker connectors for a tighter fit but I don't want to damage. Anyone else experience this? Where do I find an OE harness kit?
http://starparts.chrysler.com/starli...navigation.htm
Don't confuse the pin-out wiring order! Photos help.
