Factory infinity amp causing front right speaker crack/pop
I am getting a pop in my front right speaker. I took it in to the dealer and was told Chrysler is aware of a problem but does not have a remedy at this time. The pop/crack happens at any level above 20 and with the bass in the negatives. They replaced two speakers and told me the bass was to high. I had to persuade the service rep to come out to listen and I showed him how it would distort with bass set low. If I set balance all the way to the right it goes away even with bass and volume cranked up. I ended up replacing the head unit hoping to fix this and I am still having the same issue. I can only control it now by the setting the hpf to 100hz. It really sucks having my speakers cutting out at 100 and my sub at 60s. I am thinking the amp is now the cause even after the dealer told me it wasnt. Anybody have any ideas on what the problem could be? I have searched for amps and cannot find any replacements. I'm assuming pre 11 amps will not work. I have a 12 Jeep Wrangler w/ infinity system.
Also, my lights dim if I roll my window past max. This is not intentional but I happened to notice it by hitting the wrong button while driving. The radio now dims the lights after the addition of a sub and amp. Could this be a power issue for the factory amp to distort? I thought a 160amp alternator would be plenty of juice for the whole stereo system. I was thinking of upgrading the big 3? I appreciate any help.
The dimming lights - make sure your grounds are exceptional for your amp(s), wire is good quality/big enough gauge and upgrade your big-3. I don't know what other draws you have on your system (aux lights, silverstars, etc...) the stock alt should be good for a modest system upgrade, but obviously every added accessory will make a difference.
Otherwise, what you're seeing is fairly par for the course.
Is there any way to fix it? I assume by what your saying an amp replacement would not fix the problem. Should I try some kind of frequency (bass) blocker for the front. I have the hpf set to 100hz now and get an occasional pop. I would think a 120 cut off would be safe. The worst part is with the Pac harness I have no fade so all of the speakers are limited to that frequency even the factory sub. Appreciate any help.
