Factory infinity amp connectors
Does anyone know if the audio output from the Head Unit to the Amp in the factory Infinity system uses an RJ45 connector? I'm asking because I would like to use a Infinity Kappa Five amp (which uses a RJ45 input) to replace the factory amp. If an RJ45 is used in the factory system this should be pretty easy swap. If this has already been discussed I apologize, please refer me to the right thread, as I could not find one. Any answers/thoughts/opinions are appreciated. - Paul
You mean like a single rj45 connection from a 10/100 network cable for instance? No. Search for "stock infinity amp" JulietKilo has a great write up and i believe pictures of the amp and connections.
