factory infinity system with aftermarket headunit?
Old Apr 27, 2007 | 07:16 PM
The_Superhoo's Avatar
Default factory infinity system with aftermarket headunit?
i was just talking to a crutchfield rep online, and apparently you cant use the OEM sub with an aftermarket headunit?
is this true? and if so, can an aftermarket sub fit in the OEM sub box in the back?
im sorry if these are newbish questions, i've never tried an aftermarket system that wasnt somethin cheap from walmart
*edit* ok so i found another topic that PARTIALLY covers this. sorry *edit*
Old Apr 28, 2007 | 06:03 AM
JackMac4's Avatar
yeah, not true. you're going to trust crutchfield over us? Also, I'm pretty sure at least one person has put another aftermarket sub into the factory enclosure. I'm pretty sure it can be done.
Old Apr 28, 2007 | 08:19 AM
TrAvELAr's Avatar
I installed an after market HU and haven't done anything with the speakers yet. My sub works as intended.
Old Apr 28, 2007 | 07:21 PM
their explanation was that they dont know the output of the sub or something and therefore using it would cause distortion and possibly harm the unit
which didnt really make sense to me, but i dunno
Old Apr 29, 2007 | 04:37 AM
ROKLIMO's Avatar
I believe it is the amp that won't work with another head unit. The head unit and the amp communicate on the Can bus.You either have to replace the amp or drive the speakers and sub with the new head unit.
Old Apr 29, 2007 | 05:56 AM
i have an eclipse head unit installed using the metra harness and utilizing the factory amp, and speakers and sub
everything works great
Old Apr 29, 2007 | 01:47 PM
yeah im thinking that their system says that the amp wont work and therefore they assume that you have to set up something new for the speakers
Old Apr 29, 2007 | 06:39 PM
JackMac4's Avatar
As long as you get the right harness, you're all set. You have to have a harness if you want to utilize the factory infinity speakers.
Old Apr 30, 2007 | 06:36 AM
i guess that means that a harness now exists?
Old Apr 30, 2007 | 07:06 AM
TrAvELAr's Avatar
Yea. I installed one a couple of weeks ago.
