Factory radio
Factory radio
I have a 2011 jeep wrangler and the radio keeps cutting in and out changed the factory amp and put another one in and still have the problem not sure if this has anything to do with it but 2 years ago lost am/fm signal
If it's only the radio reception that cuts out (no problems playing a CD), it sounds like it could be an antenna coax problem.
A few questions.. Does the radio lose electrical power when it cuts out? AM/FM lost 2 yrs ago is it still not working? If loses electrical then determine the cause of this interruption. AM FM not working -- was the radio removed and the antenna coax unplugged? As Mr.T suggested should it play CDs 100% then you have power at head unit.& AMP is ok. therefore 1 of 2 causes on radio would be antenna or the radio itself has an internal issue ( if internal suggest check some salvage yards for another head unit).
Since the amp was already replaced, it cuts sound from every source, and it doesn't appear to loose power -- I'm concluding it's either the receiver/head unit or the wiring/connectors between it and the amp. Suggest removing and re-seating all the connectors first. Stay in touch, curious how it turns out.
